Headlight reminder/key in ignition reminder/door open tone
1993 CHEVROLET S-10
150,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
JAMIE THOMPSON2
When I turned on my headlights when it is running I get a tone like the truck is off reminding me the headlights are on. I also no longer have high beams and can only get the alarm to stop going off unless I turn the dimmer switch for the dash lights all the way down to the lowest setting. What could be causing this?
Dec 13, 2018 at 3:42 AM
It sound like the Audio Alarm Module on the convenience center is out. Here is its location so you can replace it. The high beam issue will be separate. Here is a guide to help test for power and the headlight wiring diagrams so you can see how it works:
Dec 14, 2018 at 1:34 PM
