My daytime running lights work with the switch in the off position. With the switch in the first on position all of the other lights come on along with the headlights. When the switch is placed into the final position (headlights on) all of the other lights stay on but the headlights go off. The dimmer switch has no effect. I replaced the main on/off switch and have the same results. I could not find a relay marked "headlights" and the 50 amp fuse is good. Where should I look and what should I test next? Thank you for your help
Jan 27, 2019 at 2:08 PM
