Hi there, car listed above is the Premier Edition it has a headlight out on the passenger side. The headlight is a HILO light and I bought and replaced the bulb and still will not work. I swapped the bulb from the driver side to the passenger side and put the new bulb in the driver side socket and the new bulb lights up fine and old bulb doesn’t work in passenger side socket. I tried jiggling the harness to see if the light would come back on indicating a shirt but no luck. I also checked the fuse panel and no blown fuse. Could this be a connection issue or would I have to replace the whole wire harness?
Sep 12, 2019 at 3:52 PM
