There is a 50-amp maxi-fuse, but it also protects the tail lights/running lights. If the tail lights work, that fuse is okay. Because power windows, wipers, and head lights are considered safety systems, they are protected by auto-resetting circuit breakers. If there is an intermittent short, a blown fuse will leave you unable to see. With an auto-resetting circuit breaker, there is at least a chance it will reset in time to resume operation.
This guide will help you see where you are losing power and which fuses run the headlight in the headlight wiring diagrams below so you can see how the system works as well.
The circuit breaker for head lights is built into the head light switch. It is not uncommon for the contacts in the circuit breaker to become arced and fail to make contact, but it is just as common for two terminals in the connector to become overheated. You will need to inspect the connector to see if part of it is melted. If you find that, I will describe how to repair it. Depending on which terminal is overheated, you may not have the flash-to-pass function either.
Check out the diagrams (Below). Please let us know what you find.
Jan 31, 2018 at 9:36 PM
