Headlight dim
2002 MERCURY SABLE
186,000 MILES • 6 CYL • FWD • AUTOMATIC
JAMESNYDER
  • 12 POSTS
The headlight is dim on the passenger side, I need to know where the multifunction switch is location and what it looks like. I know it is not getting a good ground.
Feb 16, 2016 at 9:44 PM
WRENCHTECH
  • 20,761 POSTS
The multifunction switch is the turn signal switch in the steering column.
Feb 17, 2016 at 2:12 AM
JAMESNYDER
  • 12 POSTS
When I took the headlight assembly from the driver's side and plugged the pigtail in to the passenger side the headlight wouldn't work.
Mar 1, 2016 at 3:23 AM
JAMESNYDER
  • 12 POSTS
If you could help me out I would appreciate it. This dim headlight is driving me crazy. I checked the ground wire and changed the headlight switch in the dash. I checked all the fuses and the auto headlights, the only thing that work's in the auto position is the parking lights. The fog lights will not even come on in the auto position.
Mar 1, 2016 at 3:29 AM
WRENCHTECH
  • 20,761 POSTS
There is only two issues it can be. The bulb is losing either ground or power and you have to find out which one before going any further.
Mar 1, 2016 at 8:06 AM
