How they are changed depends on which lighting option you have. They could have LED or halogen bulbs. The halogens are changed by removing the highlighted covers. The large covers are the low beam; the smaller ones are the high beam. With the covers off the bulbs or sockets are replaced by rotating them counterclockwise. Then remove the electrical connection. Reverse the process to install the new bulbs, BUT be very careful, you cannot touch the glass on the bulbs, if you do, they will need to be cleaned with alcohol to be sure there is no residue on them.
If you have the LED bulb version, the lamps are not replaceable, instead the complete headlamp is replaced. To remove the LED headlamps, you need to remove the grille, then the lower bumper cover. Now with them out of the way you unbolt the lamp housings and disconnect them. Reverse the process to install the replacements.
The replacement LED assemblies are 561941773A Left 561941774A Right. Be setting down when you look up the prices!
Jul 27, 2025 at 2:37 PM
