Okay, if I am reading this correctly. The right DRL is not working and the tail lights only work if you step on the brakes. But the turn/hazards work in the rear.
When you turn on the headlights do all of the high and low beams work?
For the tail lights it sounds like a bad power feed from the brown wire.
Check the park lamp relay in the under hood fuse box to be sure it is okay. Then use a test light on the brown wire at the rear light junction box. If you have power there then look at the brown wires at each tail light. If you have power at those then verify that the grounds for the lights are good.
Dec 9, 2020 at 12:14 PM
(Merged)
