It is pretty straight forward, just disconnect the wiring from the bulb and remove the retainer ring. Check out the images (below). Let us know how it goes
Image (Click to enlarge)
Aug 31, 2025 at 10:29 AM
SMCJACKSON
MEMBER
1 POST
I need to replace the entire headlight not the bulb.
Sep 3, 2025 at 10:21 AM
CERTIFIED EXPERT
Gotcha, here is how to change out the headlight lens. You will need to remove the upper plastic above the lenses. Here are the fasteners you need to remove. Check out the images (below). Let us know how it goes
Sep 3, 2025 at 10:24 AM
SMCJACKSON
MEMBER
1 POST
How do you remove the fasteners?
Sep 4, 2025 at 11:40 AM
CERTIFIED EXPERT
Use a 14 mm quarter-drive, deep well socket to release the headlamp assembly retaining clip. Check out the images (below). Let us know if you need anything else.
