Headlight adjustment screws location needed
1987 MERCURY COUGAR
84,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
JESSEL418
Where are the headlight adjustment screws located on my car listed above? Where can I find a diagram?
Feb 16, 2021 at 8:05 AM
They are going to be in the upper corners depending on which side you are looking at. Take a look at these pictures that will give more detail.
Here is a video on how to adjust these. Clearly your adjuster is in a different position but the process is the same.
https://youtu.be/c0757W_hZ6g
Let us know if you have other questions. Thanks
Feb 17, 2021 at 5:07 PM
JESSEL418
Thank you.
Feb 19, 2021 at 6:25 PM
