headlight not working
2000 FORD FOCUS
110,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
HEADLIGHT
Front Headlight (right side) does not work. Servo-engine for adjusting the beam also.
all fuzes are okay?
Oct 27, 2018 at 2:21 PM
Did you replace the bulb? If not here is a guide to help step by step with a diagrams below to show you how on your car also I have included the wiring diagrams so you can see how the system works.
https://youtu.be/LzdJeeeRvvs
If you have replaced the light use this guide to test to see where you lose power. Test for power at Fuse 26 and 16.
Check out the diagrams (Below). Please let us know what happens.
Oct 28, 2018 at 5:40 PM
