Most likely bad ballast.
Removing headlight:
1.Remove the front bumper cover. For additional information, refer to BUMPERS .
2.Remove the headlamp assembly pin-type retainer.
3.Remove the 4 bolts and the headlamp assembly. Disconnect the electrical connectors.
4.To install, reverse the removal procedure
Removing bumper cover:
2.Remove the 6 pin-type retainers (3 each side).
3.Remove the 8 fender splash shield screws (4 each side).
4.Remove the 4 air deflector bolts.
5.If equipped, disconnect the fog lamp electrical connectors.
6.Remove the 5 bolts from the top of the radiator grille.
Apr 26, 2020 at 11:17 AM
(Merged)
