HeadLamp Continously Stays On after removing the key from Ignition Switch
2012 FORD FIESTA
17,467 MILES • 1.4L • 4 CYL • TURBO • 2WD • MANUAL
NILESH_K
Hi Sir,
I am facing one problem in my ford Fiesta since last 2 days . Headlamps stay continuously on after removing the key for the ignition switch , due to which battery drained out completely which resulted in cranking problems.
My car was completely dead last evening when I went to start it . At last I had to jump start my car with the help of
one of my friends car . But again I am not sure whether the problem has completely solved on 100 % .
Please let me know the solution since my car is in warranty period .
Regards
Nilesh K
Mar 2, 2015 at 8:55 PM
HMAC300
  • 48,601 POSTS
hav it scanned for codes it may be body module or drl module problem. it's still under warranty so dealer can do for free
Mar 3, 2015 at 7:25 AM
NILESH_K
Hi Hmac,
Thank you for reverting .My dealer has checked for every thing & scanned the car as well,scanner didn't show any wrong codes . Eve then since I got my car last evening its working fine . But again I am worried that the same problem may occur in future . So please guide me accordingly & what precautions shall I take ?
Regards
Nilesh K
Mar 6, 2015 at 1:50 AM
HMAC300
  • 48,601 POSTS
if it happens again pull the fuses for headlights in under hood fuse boxl until you can get it to repeat more often an d hopefully by then i'll have amanual to trace the circuit.
Mar 6, 2015 at 7:01 AM
NILESH_K
Thank you for your valuable suggestions
Regards
Nilesh K
Mar 9, 2015 at 1:27 AM
