okay, you need to get a head check done. this is a quick and simple chemical test to check for Co in the cooling system. also, make sure that the radiator is not blocked get it removed and core cleaned a back flush will not be enough and also flush and check the flow through the heater core as well.
Feb 8, 2017 at 4:57 AM
