Good morning, I have the car listed above 1.6 Zetec. had issues with the temperature gauge shooting up under load and jumping back down very quickly when coasting. I have replaced the thermostat, bled the system the best I can. Now the temperature gauge just sits at 90 but there is now bubbling water coming through the return line from the back of the engine to the header tank. It's not boiling water as after 20 minutes of driving you can take the tank cap off and there's only a small amount of pressure and only warm as expected. The larger hose from the thermostat housing is cold in comparison to the other after coming up to temperature. I'm tempted to remove the thermostat and try running it, beyond that would I check the water pump next? There's no milky oil present and no loss of coolant, the engine runs smooth in idle and when driving.
People are saying head gasket but I can't help but feel it may be something else.
Any advice will be really appreciated.
Many thanks.
Jordan
Many thanks.
Jordan
Sep 18, 2021 at 1:13 AM
