Had coolant overflowing from the overflow tank, bubbling and spraying, but the vehicle was not overheated. Not sure if I have a water pump issue or a head gasket issue. Took out the spark plugs to check for liquid in the cylinders and found none. Ran it with the radiator cap off and had a few small bubbles but it did not bubble over, then when turned off I could hear gurgling from the radiator. Have no idea what is going on but hoping it is not the head gasket.
Dec 18, 2017 at 10:22 AM
