Here are the directions for removal and replacement. They include the torque specs as well as sequence. The attached pics correlate with the directions.
2005 Dodge Stratus Sedan V6-2.7L VIN R
Removal and Installation
Vehicle Engine, Cooling and Exhaust Engine Cylinder Head Assembly Service and Repair Procedures Removal and Installation
REMOVAL AND INSTALLATION
CYLINDER HEAD
REMOVAL
1. Perform fuel pressure release procedure before attempting any repairs.
2. Disconnect negative cable from remote jumper terminal.
3. Raise vehicle on hoist.
4. Drain cooling system.
5. Remove accessory drive belts.
6. Remove the vibration damper.
7. Remove exhaust cross-under pipe.
8. Remove the appropriate catalytic converter.
9. Remove oil pressure sensor heat shield. Disconnect oil pressure sensor connector.
10. Lower vehicle.
11. Remove upper and lower intake manifolds.
12. Remove cylinder head covers.
13. Disconnect camshaft position sensor and crankshaft position sensor connectors.
14. Reposition engine wiring harness to left side of vehicle.
pic 1
15. Remove coolant outlet connector (Fig. 17).
16. Remove timing chain cover.
17. Rotate crankshaft until crankshaft sprocket timing mark aligns with timing mark on oil pump housing.
18. Remove primary timing chain.
19. Remove upper primary timing chain guides.
pic 2
20. Remove camshaft bearing caps gradually in REVERSE sequence of installation (10-1) (Fig. 18).
pic 3
21. Remove camshafts and valvetrain components from cylinder head (Fig. 19). Note component locations for re-installation in original locations.
22. For left cylinder head removal:
^ Remove fastener securing engine oil dipstick tube to cylinder head. Remove engine oil dipstick tube.
^ Remove generator.
23. For right cylinder head removal:
^ Remove cylinder head ground strap.
^ Disconnect EGR valve electrical connector (if equipped).
pic 4
CAUTION: Ensure cylinder head bolts 11-9 (Fig. 20) are removed before attempting the removal of cylinder head, as damage to cylinder head and/or block may occur.
24. Remove cylinder head bolts in reverse sequence of installation (Fig. 20) starting with bolts 11-9, then bolts 8-1.
25. Remove cylinder head(s).
26. Remove and discard cylinder head gasket.
27. Clean cylinder head and block sealing surfaces.
CLEANING
To ensure engine gasket sealing, proper surface preparation must be performed, especially with the use of aluminum engine components and multi-layer steel cylinder head gaskets.
NOTE: Multi-Layer Steel (MLS) head gaskets require a scratch free sealing surface.
Remove all gasket material from cylinder head and block. Be careful not to gouge or scratch the aluminum head sealing surface.
Clean all engine oil passages.
INSPECTION
1. Before cleaning, check for leaks, damage and cracks.
2. Clean cylinder head and oil passages.
pic 5
3. Check cylinder head for flatness (Fig. 21).
4. Cylinder head must be flat within:
^ Standard dimension = less than 0.05 mm (0.002 inch)
^ Service Limit = 0.2 mm (0.008 inch)
^ Grinding Limit = Maximum of 0.2 mm (0.008 inch) is permitted.
CAUTION: 0.20 mm (0.008 inch) MAX is a combined total dimension of the stock removal limit from cylinder head and block top surface (Deck) together.
INSTALLATION
pic 6
NOTE: The cylinder head bolts are tightened using a torque plus angle procedure. The bolts must be examined BEFORE reuse. If the threads are necked down the bolts must be replaced (Fig. 22)
Necking can be checked by holding a straight edge against the threads. If all the threads do not contact the scale, the bolt must be replaced (Fig. 22)
CAUTION: When cleaning cylinder head and cylinder block surfaces, DO NOT use a metal scraper because the surfaces could be cut or ground. Use ONLY a wooden or plastic scraper.
1. Clean sealing surfaces of cylinder head and block.
2. Install new head gasket over locating dowels.
3. Install cylinder head to block, assuring head is properly positioned over locating dowels.
4. Lubricate bolt threads with clean engine oil and install bolts.
pic 7
5. Tighten bolts in sequence shown in (Fig. 23), using the following steps and torque values:
^ Step 1: Bolts 1-8 to 48 Nm (35 ft. lbs.)
^ Step 2: Bolts 1-8 to 75 Nm (55 ft. lbs.)
^ Step 3: Bolts 1-8 to 75 Nm (55 ft. lbs.)
^ Step 4: Bolts 1-8 to +90° Turn. Do not use a torque wrench for this step.
^ Step 5: Bolts 9-11 to 28 Nm (250 inch lbs.)
6. For left cylinder head installation:
^ Install engine oil dipstick tube.
^ Install generator.
7. For right cylinder head removal: e Install cylinder head ground strap.
^ Connect EGR valve electrical connector (if equipped).
pic 8
8. Install all valvetrain components and camshafts. Tighten camshaft bearing caps in sequence shown in (Fig. 24) to 12 Nm (105 inch lbs.).
9. Install primary timing chain, guides and sprockets.
10. Install coolant outlet connector.
11. Install cylinder head covers.
12. Connect camshaft position sensor and crankshaft position sensor connectors.
13. Install timing chain cover.
14. Install crankshaft vibration damper.
15. Install lower and upper intake manifolds.
16. Connect oil pressure sensor connector. Install oil pressure sensor heat shield.
17. Install catalytic converter(s).
18. Install exhaust cross-under pipe.
19. Install accessory drive belts.
20. Fill cooling system.
21. Connect negative cable to remote jumper terminal.
______________________________
Jul 26, 2020 at 2:14 PM
