Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Honda
Accord
Exterior Light
Headlight
Wiring
Low beam headlight do not work even though high beams works
1997 HONDA ACCORD
175,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JAMES KENNEDY2
MEMBER
1 POST
FOLLOW
low beam headlight do not work even though high beams works. I change the fuses .
Mar 12, 2018 at 11:10 AM
CERTIFIED EXPERT
There is a headlight relay that sounds like it is out. Here is the location of the relay and a test guide to help you confirm the issue:
Check out the diagrams (below).
May 17, 2021 at 12:27 PM
