Head light and tail light not functioning
2003 TOYOTA RAV4
297,543 MILES • 4 CYL • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 754 POSTS
Hello, the vehicle left rear tail light and the front right head light not functioning. I have checked the fuses and relay they are fine. I have tested the bulbs separately they are functioning but there's no power at the connector. Could you help me the circuit diagram
Mar 5, 2021 at 10:19 AM
The wiring schematics are broken into two sections, headlamps and exterior lighting. The rear tail lamp issue will be under exterior lighting. The headlamp will be under headlamp.
_______________
Pics 1 and 2 are for the headlamp. I cut the pic in half to make it more readable. I did, however, overlap them so you can follow it.
Pics 3, 4, 5, and 6 are the exterior lighting schematics. Again, I cut them in half to make it more readable, and I overlapped them as well.
______________
Here is a link you may find helpful as well:
______________
I hope this helps. Let me know if you have other questions. If you have a chance, let me know what you find.
Take care and God Bless,
Mar 5, 2021 at 9:38 PM
BLESSING EWOBOR
  • 754 POSTS
Sir, considering the 2nd diagram, it seems that the H-LP relay has no function since the circuit is ground by switch, am I right? If I am what is the function of the relay?
Mar 12, 2021 at 1:04 PM
BLESSING EWOBOR
  • 754 POSTS
How does the high beam indicator work since it is connected to the ground of both switch?
Mar 12, 2021 at 1:08 PM
The relay gets ground at the left front fender.
Mar 12, 2021 at 6:38 PM
BLESSING EWOBOR
  • 754 POSTS
What I am saying is that the whether the relay ground or not it won't stop the headlights from coming on.
Mar 12, 2021 at 9:10 PM
If the relay doesn't have ground, it will prevent the light from working. No power will be transmitted through the relay.
Mar 12, 2021 at 10:57 PM
BLESSING EWOBOR
  • 754 POSTS
Thank you.
Mar 13, 2021 at 2:55 AM
No problem. Let me know what you find.
Mar 13, 2021 at 7:28 PM
