Headlamp not working when bright lights are engaged
2001 MITSUBISHI GALANT
102,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
SD11
Headlights work on dim yet the do not work on bright light. I have replaced the bulbs and also a seared connector for one headlamp. Also checked the headlamp fuses under the hood which all are good. Could you help me solve this issue please?
Sep 18, 2019 at 1:56 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds like it might be your headlight high beam relay.Here is a tutorial showing how to test a relay .
I've attached a picture below of it's description and location under hood in the fuse/relay box.Hope this helps and thanks for using 2CarPros.
Danny-
Sep 18, 2019 at 3:46 PM
SD11
Thank you much. I will follow your instructions.
Sep 18, 2019 at 4:38 PM
DANNY L
  • 5,648 POSTS
You're welcome!
Let me know how things turn out or any further questions on this issue needed.Thanks again for using 2CarPros.
Danny-
Sep 18, 2019 at 5:39 PM
