Head gasket leak
1993 CHEVROLET SUBURBAN
240,000 MILES • 7.3L • V8
GARRWK
Doesn't overheat all the time but it gurgles when you turn the motor off which sometimes fills the reservoir up. Sometimes when radiator cap is off it will spill a little out if the top if radiator at the temperature between 100 and 210 that's what it does. idling going down the highway sometimes overheats and then not replaced radiator thermostat twice each time with a cooler thermos then the next flushed cooling system numerous times. new clutch fan but still had a tendency to overheat at times. please help.
May 20, 2021 at 10:12 PM
This could be a couple of issues. We need to start with what you suspect the issue is which is testing the head gasket. Here is a guide that will help with this:
Then we need to pressure test the cooling system just to make sure there are no other leaks.
https://www.2carpros.com/articles/radiator-pressure-test
Here is a guide that will talk about the bubbling:
https://www.2carpros.com/articles/vehicle-bubbling-noise
Lastly this could just be a radiator cap so if all this checks out, I would replace the cap and see if it continues.
Please let us know if you have other questions and what you find. Thanks
May 21, 2021 at 3:06 PM
