I coated both sides of the new head gasket with Permatex high heat copper gasket sealant and made sure the mating surfaces were spec clean and dry. However, I had kept the cam shaft and rocker arms areas soaked in engine oil and forgot to make sure that the head cylinder isn't going to drip oil on the surfaces as I was installing it. Unfortunately, that was exactly what happened. I placed the head bolts and tightened them, and now I am thinking I should remove and reinstall the head after making sure the head gasket is clear of oil, re-cleaned and re-coated. What do you think? I mean can few drops of oil on the head gasket affect how it performs? can the oil get trapped, get hot and damage the gasket later on down the road?
Sep 1, 2020 at 10:44 AM
