Head gasket
2001 VOLVO V70
120,000 MILES • 5 CYL • TURBO • FWD • AUTOMATIC
DOERAE
The coolant is disappearing quickly but I have not found a leak. The coolant warning light came on and I stopped the car immediately and turned it off. I opened the hood and looked at the coolant level and it was low. I waited thirty minutes with the hood up for the engine to cool off to add coolant but when I went to go to that, the coolant level was back up. Then this morning when I was checking the fluids, the oil on the dipstick looked strange, bubbly and lighter in color. I wiped it off and checked again and it was the same. I checked it again about ten minutes later and it was totally normal. It was particularly cold last night and this morning so maybe that has something to do with it? I checked for other signs of a blown head gasket foamy stuff on the engine oil cap and oil in the coolant tank none of that as far as I can tell. I am wondering if this sounds like It could be a blown head gasket because I should probably stop driving it if that is the case.
May 11, 2017 at 3:50 PM
JOHNNY G.JR
  • 320 POSTS
Try a compression test and/or a cylinder leak down test. Any steam exiting exhaust?
May 11, 2017 at 6:57 PM
STEVE W.
  • 15,113 POSTS
From the description it sounds like it could be a bad head gasket that is just starting to fail. As Johnny says get a pressure test on the cooling system and pull the spark plugs one at a time and look for a very clean plug compared to the others. Any coolant in the cylinder will turn to steam and clean the carbon out quick. Those two items should show you if it's a gasket issue.
May 15, 2017 at 1:44 PM
