Water in oil after engine temperature went up
2005 FORD COURIER
360,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
ANTHONY MULLAN
  • 4 POSTS
car has not overheated temperature went up but not critical and now have water in my oil.
normally the head goes under extreme heat but it has not gone into red on past normal range.
is it the head gasket? or something else?
Sep 1, 2019 at 5:08 PM
SCGRANTURISMO
  • 4,897 POSTS
Yes, this is more than likely a head gasket failure. The other choices are a cracked cylinder head or a cracked engine block, but, more than likely, it's a blown head gasket. What happens is when your vehicle's engine overheats the aluminum cylinder will warp because aluminum has a low melting point, around 900 degrees, so overheating will cause it to warp. Once it starts to warp the cylinder head will try to pull away from the cast iron block and the integrity of the head gasket will be compromised. Here is a link explaining everything:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
If you wish to repair your vehicle we can send you instructions on how to do this, please, just get back to us either way and let us know what you decide to do.
Thanks,
Alex
2CarPros
Sep 1, 2019 at 6:02 PM
ANTHONY MULLAN
  • 4 POSTS
it has not overheated but water definitely is in oil . even see water droplets on the cap.
Sep 1, 2019 at 8:14 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Yes sir, please keep us informed as to what you want to do. We are here to help if you want to fix it.
Thanks,
Alex
2CarPros
Sep 1, 2019 at 9:44 PM
ANTHONY MULLAN
  • 4 POSTS
i will replace the gasket.
Sep 2, 2019 at 12:41 AM
SCGRANTURISMO
  • 4,897 POSTS
The instructions for changing your head gasket are in the diagrams down below. If there are no installation instructions they are the removal instructions in reverse.
Thanks,
Alex
2CarPros
Sep 2, 2019 at 3:31 PM
