Here is the cylinder the head bolt torque specifications:
Cylinder head bolt (Cold engine) 23-27 Nm + (58 degrees-62 degrees) + (43 degrees-47 degrees) 2.3-2.7 kgf.m, + (58 degrees-62 degrees) + (43 degrees-47 degrees) 17-20 lb-ft + (58 degrees-62 degrees) + (43 degrees-47 degrees))
I have attached the replacement procedure with all the other bolt torque specifications as well as the sequences below.
Let me know of any questions.
Thank you.
https://www.2carpros.com/articles/how-a-cylinder-head-works
May 7, 2022 at 8:41 PM
