Headlight and dash lights flashing and transmission not shifting right
2012 CHEVROLET 1500
68,000 MILES
LINDQUIST03
Head lights and dash light flicker on off when driven and not shifted right second to third.
Feb 4, 2019 at 6:25 PM
It sounds like the BCM is going out, but to be sure we must scan the CAN. Here is a video that shows how and the headlight wiring diagrams so you can see how the system works with the BCM location so you can replace it. It must be programmed to the car which will run about $130.00.
https://youtu.be/InIlnsjOVFA
I would try removing the electrical connector from the BCM and then plug them back in again this can sometimes fix a bad connection. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Feb 6, 2019 at 2:12 PM
LINDQUIST03
Found a corroded ground strap replaced and is working fine now thanks for the help
Feb 7, 2019 at 10:34 AM
Nice work, we are here to help, please use 2CarPros anytime. Can I ask where the ground strap was?
Feb 7, 2019 at 10:35 AM
