IT sounds like either the flasher is bad, or the switch itself. For it not to flash as all, power is stopped at some point. When this happens, you need to check to see if there is power to the flasher (under dash / or could be in the power distribution box under the hood). If there is power, switch out the flasher. If there is no power, you will need to get into the steering column to check for power in and out of the signal switch.
Mar 21, 2019 at 6:48 PM
(Merged)
