I looked through the schematics for your vehicle. Make sure the two fuses in pic 1 are good. Both are located under the dash. Check both that I indicated. If they are good, then the next step would be to check for power to the relay. There are two supplies, a red wire with a white tracer, and the other one is white with a light blue tracer. If there is power to the flasher, then confirm it makes it to the switch.
Next, if you look at pic 2, I highlighted the power supply for the signals from the switch to all lights including the instrument panel.
If power makes it to the switch and isn't coming out, the switch is the most likely suspect.
If you determine the switch is bad, here are the directions for replacement specific to your vehicle. The remaining pics correlate with the directions.
___________________________________
2002 Ford Truck F 150 4WD Pickup V8-5.4L SOHC VIN L
Multifunction Switch
Vehicle Steering and Suspension Steering Steering Column Service and Repair Procedures Steering Column Switches Multifunction Switch
MULTIFUNCTION SWITCH
Removal
1. Disconnect the battery ground cable.
2. Remove the ignition switch lock cylinder.
pic 3
1. Insert the ignition key into the ignition switch lock cylinder and turn to the RUN position.
2. Insert a punch through the hole in the lower steering column shroud and push the ignition switch lock cylinder release tab while pulling out the ignition switch lock cylinder.
pic 4
3. Twist the tilt wheel handle and shank and remove.
4. NOTE: Move gear selector to lowest position to access steering column opening cover.
pic 5
Release the four clips and remove the steering column opening cover.
5. Remove the upper and lower steering column shrouds.
pic 6
1. Remove the three screws.
2. Remove the lower steering column shroud.
3. Remove the upper steering column shroud.
6. Remove the multi function switch.
pic 7
1. Remove the two screws.
2. Disconnect the electrical connectors.
3. Remove the multi function switch.
Installation
1. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi.) or more to relearn the strategy.
pic 8
To install, reverse the removal procedure.
I hope this helps. Let me know how it goes. Also, if you have other questions, let me know.
Oct 14, 2020 at 2:53 PM
(Merged)
