Hazard light not functioning?
2006 TOYOTA HIGHLANDER HYBRID
204,567 MILES • 6 CYL • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 754 POSTS
Hello, the vehicle hazard light is not functioning when the button has been pressed but both the left and right turn signal lights are functioning. What could be the cause?
Could I get I wire diagram for this?
Thank you very much.
Sep 4, 2023 at 12:05 PM
I'm not sure if this is a hybrid or not. I went with a non-hybrid.
There is a fuse specific to the hazard lights. It's fuse 15 in the under-hood fuse box. However, I believe that is for the signals as well. If they are working, I suspect it will be good.
I attached the wiring schematic for you below. As always, I cut it in half but overlapped it so you can follow from one to the next.
Let me know if this helps.
See pics below.
Sep 4, 2023 at 10:04 PM
BLESSING EWOBOR
  • 754 POSTS
Thank you very much sir.
Sep 5, 2023 at 4:04 AM
BLESSING EWOBOR
  • 754 POSTS
The hazard fuse is okay, I wanted to test the hazard switch but when I removed it. It was assembly. I don't know how to test it and there are two red wires on the connectors, if I have to use the wire diagram.
Sep 5, 2023 at 9:48 AM
I see that. I do see two reds going into the center JB in the schematic. Do me a favor. Take a look at the diagnostics for the hazard lights circuit below. One is for a vehicle with navigation and the other is for one without.
Let me know if you are able to test from that information.
joe
See pics below.
Sep 5, 2023 at 6:11 PM
BLESSING EWOBOR
  • 754 POSTS
Thank you very much for the information.
From the picture that I sent, it seems that the vehicle that I am working on is without navigation, if I am right?
Then from the guide, does it mean that if the switch is bad, the A/C assembly will be replaced, or can the hazard switch be replaced alone?
Sep 5, 2023 at 8:37 PM
You should be able to replace only the switch. It has been a while since I've seen one of these, but the switch should be separate.
Sep 6, 2023 at 4:52 PM
BLESSING EWOBOR
  • 754 POSTS
Good morning,
From the A10 has two connectors. which of the connectors, will be tested for?
Sep 6, 2023 at 8:13 PM
With the switch off and on, you are checking resistance as indicated in pic 2 above. Is that what you needed?
Sep 7, 2023 at 1:26 PM
BLESSING EWOBOR
  • 754 POSTS
Good morning, sir,
That is not what I needed.
I mean two different connectors entered the A/C assembly. Which of the two shall we test for?
Sep 7, 2023 at 8:00 PM
See pics below. When determining pins, turn the connector in the same direction as indicated in the pic.
Let me know if that is what is needed.
joe
See pics below.
Sep 8, 2023 at 5:58 PM
BLESSING EWOBOR
  • 754 POSTS
Good evening.
Please could I have the location of the turn signal flash assembly?
Sep 19, 2023 at 12:12 PM
The signal flasher is under the dash on the left side next to the IP junction box. See pics 1 and 2 below. Pic 3 provides the part number and what it looks like.
See pics below.
Sep 19, 2023 at 9:06 PM
BLESSING EWOBOR
  • 754 POSTS
Sep 20, 2023 at 11:13 AM
