Hazard and blinkers do not work
2010 MAZDA 6
110,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
KIKER74
  • 9 POSTS
Hi Group!
I read in many forums that the possible cause could be the BCM.
After checking the fuses and light bulbs I went ahead and bought a used BCM.
I installed it but the problem persist, now I put my original BCM back in the car.
I'm not sure where else to look.
Please help.
Thanks!
Apr 18, 2020 at 6:38 PM
Lets start by making sure there is power at the stop and hazard fuses. here is a guide to help you, the key should be on before you begin. Also I have included the fuse location and the blinker and hazard light wiring diagrams so you can see how the system works.
Apr 18, 2020 at 7:08 PM
KIKER74
  • 9 POSTS
Thank you I'll check again tomorrow.
Apr 18, 2020 at 8:16 PM
Apr 20, 2020 at 9:58 AM
KIKER74
  • 9 POSTS
Hello group,
I went and got another continuity tester and tested the fuses again and this time the hazard fuse did not work.
Learning lesson: Use more than one tester.
May 2, 2020 at 8:45 PM
When you replaced the fuse did it work? Tester can mislead us when they dont work DOH!
May 3, 2020 at 12:15 PM
