Put car on lift removed the shroud. Looks like the coolant leak is coming from gasket area on the drivers side on the bottom of engine.
Apr 20, 2017 at 2:14 AM
HMAC300
CERTIFIED EXPERT
this may be a head gasket leak. use a pressure checker and pressurize the coolant system to verify there is a chemical you can also add to verify as well either is okay. auto parts rent a pressure checker.
