When re-installing a harmonic balancer on a crankshaft, how close should the hub snout of the balancer be to the seal in the timing cover when completely installed? Should there be at least a slight gap or should the balancer hub snout be just barely butted up to the seal? The harmonic balancer I'm installing has about 1 to 1.5 millimeters gap between it and the seal, but the pulley is not quite even with the pulley on the alternator when I use a straight edge to check. I may be able to press the balancer on slightly further but I wanted to check first out of fear of pressing it on too far and damaging the seal when the motor is fired up.
Dec 11, 2019 at 10:31 AM
