I replaced the harmonic balancer and the timing cover. When I put the new harmonic balancer on, there wasn't much clearance between the balancer and the timing cover. After I started the truck, It was scrubbing the timing cover. Is it possible, to install the balancer to far on the snout or is there a spacer to prevent it from going back too far? I used a balancer removal tool to take it off and to press it back on. I then used an impact to tighten the bolt.
Jan 13, 2021 at 6:11 AM
