I have the vehicle listed above with a 22RE engine. It will crank perfectly after it has sat, and the engine is cold. Once I crank it and the engine warms up, if I turn off the engine, it doesn't want to start back up until the engine has cooled down. I recently replaced the MAF sensor, cold start injector thermo time switch, ECU temperature sending unit, and the coolant temperature sensor for the gauge. None of these replacements fixed my problem. I can hear the fuel pump turn on when the ignition switch is turned on, and I can hear the circuit opening relay for the fuel pump making a "click" noise like it's supposed to. I am at a loss on what to check next. Any help would be greatly appreciated! Thanks!
Dec 4, 2023 at 10:34 PM
