Engine is hard to start?
2010 CHEVROLET IMPALA
170,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
VINNIE LEFTKOWITZ
My car barely starts when cold. Runs rough. I give it some gas and it shakes some then then after warming up it is okay. It starts fine after I shut it off after warm up. Codes P0449 and P0442 and P0445 came up when I took it to AutoZone. I replaced to throttle body and the purge valve for the vapor canister. What could I check next?
Jan 30, 2020 at 7:46 AM
I have seen the engine coolant temperature sensor cause this issue not reading correctly while giving the computer a false reading. You can get a scanner to see what the reading is cold to see if it is close to outside temperature to confirm the issue. here's a guide to help and the coolant sensor location so you can check it out:
and
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Jan 30, 2020 at 10:52 AM
VINNIE LEFTKOWITZ
No code came up for the coolant sensor when I took it to autozone to get scanned.
3 codes did come up. P0449, P0442,P0445. Are you saying I need buy my own code reader and scan for codes?
Jan 30, 2020 at 12:14 PM
The sensor may not give a code, the P0449, P0442, P0445 are EVAP codes which wont affect the engine running. Have we serviced the throttle body latey? if not this guide can help you:
A scanner is a good idea for anyone that owns a car, you can use it all almost every car out there.
Feb 1, 2020 at 10:25 AM
VINNIE LEFTKOWITZ
I put a new throttle body on a week ago and a new purge valve for the vapor canister.
Feb 2, 2020 at 12:05 PM
Sorry, I missed that in the first post. A vacuum leak will cause hard starting also, I would look into the coolant sensor as well, what happens is the sensor range gets off a little (not enough to give a code) but enough to cause engine problems. Did you clear the codes once the new parts were installed?
Feb 4, 2020 at 11:08 AM
