Hard to start issue
2006 FORD FALCON
104,561 MILES • 4.0L • 6 CYL • RWD • AUTOMATIC
ALBISH
  • 4 POSTS
Vehicle stopped while driving. pulled over to start but no fire. had vehicle towed home have replaced battery, cam sensor and crank sensor.
Vehicle will crank and back fire but will not start. engine light and etc light on dash.
Jun 16, 2017 at 4:36 AM
HMAC300
  • 48,601 POSTS
if starting with starting fluid check fuel pressure with a gauge in US auto parts rent it. You may need an adapter as well to test. See link.
Jun 16, 2017 at 6:47 AM
ALBISH
  • 4 POSTS
Fuel pump is okay
I have replaced both cam sensors and crank sensor and replacing same issue I have removed number coil and and I have spark ??
Jun 17, 2017 at 12:30 AM
HMAC300
  • 48,601 POSTS
try a security system reset if you have a manual it may be different from US cars but i will send our link any how. See link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Jun 17, 2017 at 12:06 PM
ALBISH
  • 4 POSTS
The security system isn't the problem
The etc light is on and after clearing all fault codes it stays on
Jun 17, 2017 at 5:45 PM
HMAC300
  • 48,601 POSTS
well we have no info on this so not much else we can advise unless you have broken a timing belt/chain etc.
Jun 18, 2017 at 7:15 AM
ALBISH
  • 4 POSTS
Thank you that is where you are correct I removed the rocker cover to inspect and found the timing chain have broken.
What would cause this and what damage am I going to find ?
Jun 18, 2017 at 8:02 AM
HMAC300
  • 48,601 POSTS
it depends if it is an interference engine or not. if it's an interference engine then you are going to h ave bent valves if not it will be ok. but we have no info on this car so can't tellyou
Jun 18, 2017 at 1:44 PM
