If the car is not driven or sits overnight, it takes hard cranking to turn on the engine. The dash light would be on normally without dimming, there are no clicking sounds. If it is driven, then starting the car afterward is no problem. Then one day after parking the car for 3 days, the car would not even start. There was no cranking sound either. There was still light on the dashboard. I replaced the battery with a new Honda battery and the cranking symptoms still persist. On days that I don't drive, I turn on the engine and let it idle for a few minutes then turn it off then turn it on after many hours later. The engine would turn on but with some cranking but at least it didn't die completely. When the car is driven then again there is no problem with starting the engine.
The attached video shows the hard cranking with the new battery already installed.
Aug 30, 2022 at 7:03 PM
