Hard to start
2001 GMC JIMMY
141,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
EDWARD CONNOR
  • 7 POSTS
Changed the fuel pump and filter on my vehicle. It is hard to start. Sometimes it starts right up other times it takes a while. On the times it takes a while it sounds like it backfires. After it starts you can smell fuel. The codes always show for the EVAP Canister Purge Solenoid. I have checked and installed all new EVAP parts except the canister. It runs pretty good on flat ground but not so good on climbing hills. Service engine soon light flashes when it drops a gear to climb the hill. Checked fuel pressure at the filter and I get 40 psi. Have not checked it at the regulator yet. Fuel economy has dropped also. This Jimmy used to smoke the tires. Now it barely puts you back in the seat on flat ground. What am I missing?
Oct 22, 2018 at 9:43 AM
Good afternoon.
Can you tell me the code and what parts you replaced?
As far as the hard start, there is a spider assembly that contains the injectors and the regulator. The regulator is common for leaking raw fuel into the intake causing a flooding condition.
I would start with a fuel pressure test to verify fuel pressure especially when it sits overnight.
It sounds like you will possibly need the spider assembly.
1. Disconnect the negative battery cable.
2. Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure.
3. Remove the upper intake manifold assembly.
NOTE: Do not use any solvent that contains Methyl Ethyl Ketone (MEK). This solvent may damage fuel system components.
4. Before removal, clean the fuel meter body assembly with a spray type engine cleaner, GM X-30A or the equivalent, if necessary. Follow the package instructions. Do not soak fuel meter body assemblies in liquid cleaning solvent.
NOTE: Cover the injector sockets in order to prevent dirt and other contaminants from entering the open fuel passages.
IMPORTANT: When disconnecting the poppet nozzles, remember the sequence in order to ensure correct poppet nozzle placement to each cylinder.
5. Squeeze the poppet nozzle locking tabs together while lifting the nozzle out of the casting socket.
6. Remove the fuel meter body from the bracket by releasing the lock tabs on the bracket.
Oct 22, 2018 at 11:23 AM
EDWARD CONNOR
  • 7 POSTS
The only code is P0446 Emission EVAP System. I have replaced the fuel pump, filter, EVAP Solenoid on the intake, spark plugs and wires, coil, and gas cap (non-locking style).
In 2015 we had a flood. Out of five vehicles, the Jimmy was the only vehicle that the water only got as high as the seat mounts. Yes the seat motors are shot. The Jimmy was the only one I could start and drive after the water receded. I did have to replace the transmission about six months ago. I am sure the EVAP problem is because of the flood. The canister is clean and the solenoids work just fine. Water never got into the engine. Wish I could say the same for my 1984 El Camino SS Choo Choo Custom(all original), 2007 Impala, 1995 Toyota Avalon, and 1976 Chevy Step side 4X4. Late 2016 the Jimmy's fuel pump quit. Changed that and it ran fine for a while then started taking longer to start. More than a couple seconds. The new pump had the new 4 pin connector so I did the conversion per instructions. Other than that it has been a fantastic truck. I have even used it, in the past, to haul the El Camino to car shows without any issues. Still looks brand new.
Oct 22, 2018 at 1:30 PM
Is the 446 still active?
Oct 22, 2018 at 1:40 PM
EDWARD CONNOR
  • 7 POSTS
I erase it every time it comes up. It just keeps coming back. Does not seem to make a difference. Erased or active it is still hard to start. The code pops up after the engine starts and smooths out to idle.
Oct 22, 2018 at 2:40 PM
Okay, clearing a code does nothing. It needs to be diagnosed and repaired. Besides, it has no effect on your current issue.
Again, what parts have been changed?
CIRCUIT DESCRIPTION
The Power-train Control Module (PCM) monitors the performance of the Evaporative Emission (EVAP) system by applying a predetermined level of vacuum to the EVAP system then monitors the vacuum decay rate. The PCM sets this Diagnostic Trouble Code (DTC) if the vacuum decay rate is more than a predetermined value.
CONDITIONS FOR RUNNING THE DTC
^ DTCs P0107, P0108, P0110, P0112, P0113, P0115, P0117, P0118, P0121, P0121, P0122, P0123, P0125, P0440, P0442, P0443, P0449, P0452, P0453, P1106, P1107, P1111, P1112, P1114, P1115, P1121, or P1122 are not set.
^ The ignition voltage is between 10-18 volts.
^ The Barometric Pressure (BARO) is more than 75 kPa.
^ The fuel level is between 15-85 percent of full capacity.
^ The Engine Coolant Temperature (ECT) is between 4-30°C (39-86°F).
^ The Intake Air Temperature (IAT) is between 4-30°C (39-86°F).
^ The start up ECT and the IAT are within 9°C (16°F) of each other.
CONDITIONS FOR SETTING THE DTC
IMPORTANT: This DTC does not report a first failed test. A first fail of this DTC will have a scan tool status as Not Run.
^ The EVAP vacuum decay rate is more than a predetermined value.
^ The conditions are present for more than 2 seconds.
OR
^ The vacuum present in the EVAP system is more than a predetermined value.
^ The conditions are present for more than 4 seconds.
ACTION TAKEN WHEN THE DTC SETS
^ The control module illuminates the Malfunction Indicator Lamp (MIL) when the diagnostic runs and fails.
^ The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame/Failure Records.
CONDITIONS FOR CLEARING THE MIL/DTC
^ The control module turns OFF the Malfunction Indicator Lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
^ A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
^ A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
^ Use a scan tool in order to clear the MIL and the DTC.
DIAGNOSTIC AIDS
IMPORTANT:
^ Remove any debris from the PCM connector surfaces before servicing the PCM. Inspect the PCM connector gaskets when diagnosing or replacing the PCM. Ensure that the gaskets are installed correctly. The gaskets prevent water intrusion into the PCM.
^ An accurate indication of fuel level is required for the PCM to properly pass or fail this DTC. Always diagnose the fuel level sensor DTCs before using the diagnostic table for this DTC. Always inspect for fuel level sensor DTCs that are stored as History.
^ The Service Bay Test may have to be performed in cold ambient air temperatures when the vehicle is running a winter grade fuel. The scan tool displays a message when the Service Bay Test does not run.
^ Inspect for a charcoal release from the vapor canister. Refer to Evaporative Emission (EVAP) System Cleaning procedure. See: Evaporative Emissions System > Procedures > Evaporative Emission (EVAP) System Cleaning
CONDITIONS FOR RUNNING THE SERVICE BAY TEST
^ The battery voltage is between 10.5-17.5 volts.
^ The fuel level is between 15-85 percent of the full capacity.
^ The engine temperature is between 3.5-35°C (38-95°F).
Perform a physical inspection of the EVAP system. Inspect for the following conditions:
^ A loose, missing, defective, or incorrect fuel tank cap
^ Incorrectly routed or defective EVAP system vacuum and vapor lines
^ A malfunctioning or damaged vapor canister
^ Charcoal release from the vapor canister-Refer to Evaporative Emission (EVAP) System Cleaning. See: Evaporative Emissions System > Procedures > Evaporative Emission (EVAP) System Cleaning
The vacuum and pressure in the EVAP system is measured in inches of water (H2O). Most gauges measure vacuum in inches of mercury (Hg) and pressure in pounds per square inch (psi). The table shows how the values compare.
Oct 22, 2018 at 2:45 PM
EDWARD CONNOR
  • 7 POSTS
Spark plugs and wires, Evap solenoid on intake, Ignition coil, gas cap, fuel pump and filter. I forgot that the TPS and Mass Airflow has been changed also. The butterfly and throttle intake were cleaned when the TPS and Mass were swapped.
Oct 22, 2018 at 3:04 PM
Okay, so the purge valve was the only thing replaced for the evap system issue.
I would check the vent valve for the fuel tank. It may be stuck open causing this code.
You need a scan tool to work the valve and see if it opens and closes on command.
. Turn OFF the ignition.
2. Raise the vehicle.
3. Remove the spare tire (underbody mounted spare tire only).
4. Disconnect the EVAP canister vent valve harness connector.
5. Disconnect the vent hose (1) from the EVAP canister vent valve (2).
6. Release the tang on the vent bracket (4).
7. Remove the vent valve (2) from the bracket (4).
Oct 22, 2018 at 3:11 PM
EDWARD CONNOR
  • 7 POSTS
I used some test leads and a battery to check the vent valve. It cycled without sticking. I could not blow through it when it was closed. This was done completely off the system and with a red top battery. I got that check from a Haynes manual.
Oct 22, 2018 at 3:40 PM
Okay, and it opened as well and you could blow through it?
Was there voltage to the solenoid with the key on?
Oct 22, 2018 at 3:47 PM
EDWARD CONNOR
  • 7 POSTS
Yes and yes. I used my multi-meter to check for voltage at the connector. 12 volts all day. I also get voltage at the purge solenoid. Same blow no blow. You can see why I am scratching my head.
FYI. I am a generator mechanic in the Army National Guard. I do Calibrations as a Federal Technician. If this was my 1976 Chevy or my 1984 Elky I would not have this problem. LOL!
Oct 22, 2018 at 4:28 PM
Thanks for your service.
Okay, the PCM is what grounds or opens and closes those solenoids.
That is why you need a scan tool to see if it is doing its job. It may very well be a failing PCM.
Oct 22, 2018 at 5:02 PM
EDWARD CONNOR
  • 7 POSTS
Thank you for your service also. I hope its not a PCM. I will not even start with the ABS and brake idiot light. I am hoping it is just a bad connection at the wheel sensor and not the module. That is another issue for another time. I will look into the Spider Assembly for the fuel. Have to wait on payday. And the time to do it. LOL! I will do the assembly and regulator at the same time since I will have the top of the engine off. They could not put the thing on top where it is easy. Thank you for all your help.
Oct 22, 2018 at 5:18 PM
You are welcome.
Oct 22, 2018 at 5:27 PM
