Only when the engine is hot and sits for about an hour, when I turn the starter key, the starter clicks and may or may not turn the engine over. When cold, it starts right up. I have replaced the battery with a 1000 CCA unit and same problem. I have verified the alternator is working correctly. I get 14.1 volts when the engine is idle and 14.2 at 2,500 rpm. I checked the voltage at the battery with engine off and have 12.1 volts. I also checked during cranking and/or clicking and have a voltage of 11.3. Does this mean the starter is bad?
Nov 28, 2018 at 8:56 AM
