hard starting (like it is flooded) after fuel injector replacements
1999 TOYOTA TACOMA
163,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
GREG BEARD
requires two to three key turnovers to start. compare that to my 4-Runner with the same size motor V6 3.4L which starts in two cranks hot or cold.
Feb 20, 2017 at 11:17 AM
JDL
  • 16,098 POSTS
If you turn the key on and off several times with out cranking, it may help to prime the fuel system. If that is the case, have to check fuel system, use a gauge and check proper fuel pressure. How long since a tune-up? If fuel issue, have you ever changed the fuel filter? There could be other issues?
Feb 20, 2017 at 12:28 PM
RENEE L
  • 1,260 POSTS
Hi GREG BEARD,
Here is a helpful link to an article from this site with step by step instructions and pictures explaining the process of checking the fuel-system-pressure-and-regulator.
If you need further assistance please come back to the site we are here to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Feb 20, 2017 at 3:00 PM
GREG BEARD
Thanks for all the input and advice. I did a tune up two months ago and I also replaced the fuel filter. I just cleaned the MAF as it started throwing codes P0171 which fixed that issue. I will clean the IAC and I have my old injectors being reworked and will put those in to see if that fixes the hard cold start issue.
Feb 20, 2017 at 5:28 PM
Please let us know happens so it will help others.
Best, Ken
Feb 23, 2017 at 12:03 PM
