Hard starting
2001 MITSUBISHI SPACE STAR
190,432 MILES • 2WD
OSENIRONALD
  • 6 POSTS
It only happens in the morning when never try to start. It will take about 2 to 3 times before it gets started.
Mar 31, 2020 at 7:53 AM
Most likely this is a fuel pump or fuel supply issue.
We need to start with checking for fuel pressure. I suspect when you turn the key that your pressure will be low. If that is the case then we need to most likely replace the pump.
However, we need to first check pressure. Here is a guide that helps with that. Let me know what the pressure is and we can go from there.
If you don't have a pressure gauge then we need to find a tool rental store and they should rent them to you pretty cheap.
Let me know if you have questions. Thanks
Mar 31, 2020 at 8:54 AM
OSENIRONALD
  • 6 POSTS
Thanks. More also can built up carbon be scrapped from Mitsubishi space star GDI engine? Is it the same hard starting sometime cause hesitation why accelerating and later pick up on the road?
Mar 31, 2020 at 11:31 PM
Carbon build up can cause this because when the engine heats up the carbon will actually heat up as well. However, it is normally not going to cause this issue by itself. Meaning if you just decarbon the engine it will fix the issue. Normally the carbon is a symptom of a greater issue.
I would suggest performing this de-carbon procedure with one of the chemicals you spray in the intake and then clean the throttle bore if it is dirty.
If you perform this and then retest hopefully it resolves your issues. However, you cannot actually scrap the carbon off the pistons unless you take the engine apart so you will need to use a chemical that is made for this. Any parts store has a large selection of these products.
Apr 1, 2020 at 7:23 AM
