Hard starting
1997 CADILLAC DEVILLE
159,500 MILES • V8 • 2WD • AUTOMATIC
JERMIAJR42
  • 8 POSTS
Car starts very hard when it sets overnight. Have to crank a lot to start, once it does start it runs okay and will restart okay until it sets for more than six or more hours. Has new plugs. Car sat for two years without starting and running.
Oct 16, 2018 at 7:59 AM
Good morning.
I would suspect the fuel pump is losing its prime overnight.
I would start by checking the fuel pressure before starting the engine in the morning. If it is low or 0, replace the fuel pump.
Oct 16, 2018 at 8:51 AM
JERMIAJR42
  • 8 POSTS
As I am not a mechanic, I am inclined to believe that your answer to my problem may be correct. But, could it be a fuel relay that has quit working? A fuse maybe gone bad?
Oct 18, 2018 at 6:45 AM
I doubt the relay or a fuse is the issue as it does start and once it does, it stays running all day long.
Check the fuel pressure.
Removal Procedure
Notice: Numbers in text correspond to numbered components in image.
1. Relieve the fuel system pressure. Refer to Fuel Pressure Release.
2. Drain fuel tank. Refer to Fuel Tank / Service and Repair.
3. Remove fuel tank (3). Refer to Fuel Tank / Service and Repair.
4. Remove the locking nut using J 39348 by turning counterclockwise.
Important: The modular fuel sender assembly may spring up from its position. When removing the modular assembly from the fuel tank, be aware that the reservoir bucket is full of fuel. Tip the modular assembly slightly during removal to avoid damage to the float. Have a shop towel ready to absorb any leakage.
5. Remove modular fuel sender assembly from the fuel tank (4).
6. Remove fuel sender seal (lip). Slide the fuel sender lip seal downward, past the reservoir and carefully over the float arm assembly.
7. Discard the fuel sender lip seal.
8. Carefully discard the reservoir fuel into an approved container.
Installation Procedure
1. Install new lip seal on modular fuel sender assembly. Always use a new lip seal when servicing modular fuel sender unit.
Important: Lip seal should be carefully positioned over the float arm assembly, moved up over the reservoir and half way up the guide posts.
2. Lightly lubricate the inside diameter of the lip seal with engine oil.
3. Install modular fuel sender assembly (4) into the fuel tank (3). Seat lip seal into tank opening.
4. Align arrow on top of the fuel sender cover to arrow on the fuel tank.
5. Slowly apply pressure to the top of the spring loaded sender until the lip seal is flush between the fuel tank and the fuel sender cover. Tighten the locking nut and tighten locking nut to 50 Nm (37 lb ft). Be sure that the lip seal provides a snug seal between the modular unit and the fuel tank.
6. Install the fuel tank. Refer to Fuel Tank / Service and Repair.
Oct 18, 2018 at 7:21 AM
