For the past two years my car has struggled to start and has gotten worse as time passes. I have to turn the key 2-3 times and give some gas to start. If the car has been sitting for 2-3 days, it the starts up like a champ first time I turn the key without stepping on the gas.
Starter and charging system are good. I checked fuel pressure, read 30 psi and then would drop quickly, about 10 psi in under 2 minutes. I replaced the fuel filter and fuel pump. Noticed the snap ring on the tank a bit bent but was able to get it back using force. New pump holds pressure better but still low at 38-40 psi and still drops slowly, about 1 psi per 5 minutes. I've also changed lower crankshaft position sensor, camshaft position sensor, spark plugs and cables.
Prior to doing all this, I also had a few emissions system warning lights. I replaced a few things that eliminated the warning lights: the tube that runs from the intake hose to the crankcase, the EGR valve, the MAP sensor and cleaned out the throttle body and the passage to the EGR valve.
Also worth mentioning, I dropped in a used motor with 50,000 miles a few years ago, it was in great condition, passed compression test with flying colors. Motor has about 90,000, transmission about 200,000.
GM 3100
GM 3100
Apr 28, 2020 at 7:47 PM
