Hard shifting into gear when cold
1995 NISSAN TRUCK
95,000 MILES • 2.4L • 4 CYL • MANUAL
KWIKWING
Had new clutch installed 3 years ago. Everything was find until this winter. When I try to first take off while cold outside( below 40 degrees) it is very difficult to shift from neutral to 1st gear. After driving a few minutes all works good.
Feb 10, 2014 at 2:57 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
id start by just changing the trans gear oil. I like BG slick shift 2
Feb 10, 2014 at 4:45 PM
KWIKWING
Anyone have these symptoms with manual Nissan pickup?
Feb 23, 2014 at 10:17 AM
KWIKWING
Transmission grease was changed when new clutch was installed.
Feb 23, 2014 at 10:18 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
clutch fluid is the same as brake fluid and will absorb moisture out of the air and if its moist enough then the water could be freezing or causing the fluid to become thick when cold. the moisture content can be checked at service stations that do BG services. or id just bleed it all out to replace it.
Feb 25, 2014 at 4:46 PM
