Handbrake replacement?
2012 KIA SPORTAGE
184,000 MILES • 1.7L • 4 CYL • 2WD • MANUAL
ALESSANDRO ALBERTIN
  • 12 POSTS
Hi, I would like to replace the handbrake shoes, but a wheel stabilizer arm prevents me from removing the brake caliper bracket, the key just won't fit. My question is, do I have to disassemble the stabilizer bracket and the shock absorber? Or is there another system that I don't know about?
I would like to disassemble the caliper bracket, but I can't. Looking forward to your advice, thank you very much.
Jan 8, 2023 at 8:57 AM
2004 CAMRY
  • 6 POSTS
This video shows how to do it, it’s on a 2015 sportage but it is the same https://m.youtube.com/watch?v=t2T05_Nn8xU
Jan 8, 2023 at 1:33 PM
BORIS K
  • 836 POSTS
Good videos on how to on these are on 4WD:
https://youtu.be/t2T05_Nn8xU
and
https://youtu.be/jkuplVAyLlg
Parking brake shoe replacement:
https://www.2carpros.com/articles/parking-brake-shoe-replacement
If your vehicle is a 2WD you will need to remove the rear shock absorber and rear upper arm first.
The rear shock absorber has one lower bolt and 2 upper bolts holding it in.
The upper arm has 1 bolt and nut on the wheel side and 1 large bolt holding it to the rear subframe.
See image 1+2 below for the upper arm
See image 3+4 for the rear shock absorber
The inner, big bolt, of the upper arm needs to be tightened to a specific torque.
Tightening torque:
2WD
137.3 ~ 156.9N.m (14.0 ~ 16.0kgf.m, 101.3 ~ 115.7lb-ft)
Cheers, Boris
Jan 9, 2023 at 4:23 AM
ALESSANDRO ALBERTIN
  • 12 POSTS
Thank you very much, very good answer.
Jan 9, 2023 at 9:55 AM
