The handbrake wasn't holding on i800 minibus. I have replaced the shoes and drum/discs and replaced the front section of the handbrake cable as it snapped when i tried to tighten it. While the wheels were of the ground i adjusted the brake adjuster till the wheel locked and then turned it back slightly so the wheel rotates. When i pull the handbrake on the wheel it doesn't turn, but when i test the handbrake on a slight hill it doesn't hold.
Aug 20, 2024 at 10:47 AM
