Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Honda
Civic
Drivetrain
Transfer Case
Symptoms
Leak
Hairline crack in transfer case
2003 HONDA CIVIC
154,000 MILES • 1.7L • 4 CYL • 2WD • AUTOMATIC
ALEX19899
MEMBER
FOLLOW
I have a hairline crack in my transfer case, that is leaking a good amount of fluid. Will putting jb weld on the area stop the leak?
Oct 19, 2018 at 5:38 PM
CERTIFIED EXPERT
Good evening.
JB Weld may work temporarily but due to expansion and contraction, it will fall off.
My question is why did it crack? It may have run low in oil and overheated the case.
The proper repair would be to replace the transfer case with a good used unit to be sure it lasts.
Can you post a picture of the crack?
Oct 19, 2018 at 5:58 PM
ALEX19899
MEMBER
I was turning the bolt the wrong way and it cracked. I do not right now but I will tomorrow.
Oct 19, 2018 at 6:10 PM
ALEX19899
MEMBER
Here is the photo of the crack:
Image (Click to enlarge)
Oct 19, 2018 at 11:25 PM
CERTIFIED EXPERT
How far does the crack go? Difficult to see in the picture.
Oct 20, 2018 at 4:35 AM
ALEX19899
MEMBER
Eh, about an inch.
Oct 20, 2018 at 5:28 AM
CERTIFIED EXPERT
Try the JB weld. It should hold for about an inch crack.
You may need to replace it over time from it cracking off but it will save you the expense of replacing the trans-axle assembly.
Oct 20, 2018 at 5:31 AM
