Hazard lights and turn signal lights not working inside or outside
2002 HYUNDAI ELANTRA
170 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JOTAEME
My turn lights or hazard lights do not work inside or outside. I have changed the fuse, the relay and the lights stick and still do not work. What can it be?
Jun 18, 2018 at 8:53 PM
It sounds like the flasher unit is out or you have lost power or ground somewhere. Here are is the wiring diagrams and a guide to help you test the power and grounds:
Please try to move the switch back and forth several time to help clean off the contacts.
Jun 20, 2018 at 11:36 AM
JOTAEME
I Replace the hazard switch for a new one and problem solved.
Jun 20, 2018 at 5:48 PM
Nice work, we are here to help, please use 2CarPros anytime.
Jun 21, 2018 at 12:24 PM
