Gurgling sound in my gas tank while car is running?
2012 KIA RIO
156,000 MILES • 4 CYL • 2WD • AUTOMATIC
DEBRUTZ10
  • 5 POSTS
I had unrelated work done last week, ball joint, tie rod and alignment. Noticed gas mileage was up quite a lot a few days later. I decided to check the gas cap, while the car was running, to make sure it was tight, and heard this noise.
Sep 17, 2022 at 4:11 PM
DEBRUTZ10
  • 5 POSTS
The gas tank is half full. See video.
Sep 17, 2022 at 4:15 PM
Thanks for the video. Yep, that noise is not normal. It sounds like you have an EVAP control solenoid that is stuck open. Here is the location so you can change it out which should fix the problem. Check out the images (below). Please let us know what happens.
Sep 19, 2022 at 9:42 AM
DEBRUTZ10
  • 5 POSTS
Hi. Thanks so much for the reply, I really appreciate the info. Will definitely let you know how I make out. My question is, is it okay to drive? Thanks!
Sep 19, 2022 at 11:40 AM
Because the problem is fuel related, I can't say it is safe to drive, sorry.
Sep 19, 2022 at 5:39 PM
DEBRUTZ10
  • 5 POSTS
Apparently, it's a purge valve, according to my mechanic, doing what it's supposed to do, and basically, I shouldn't open my gas cap while the car is running.
Sep 20, 2022 at 11:07 PM
Can you hear it from inside the car or? How did you notice the noise?
Sep 22, 2022 at 11:58 AM
DEBRUTZ10
  • 5 POSTS
No, not from inside the car. Only when I removed the gas cap when the car was running.
Sep 22, 2022 at 4:45 PM
It could be normal then, when you release the cap is there a vacuum like sound?
Sep 23, 2022 at 12:31 PM
