Radiator was almost empty topped up with coolant now their is a gurgling sound when engine is off. Last about a minute. gurgling no leakage.
Nov 10, 2017 at 9:30 PM
MHPAUTOS
CERTIFIED EXPERT
if the coolant was that low there will be a leak. get a coolant pressure test done to check for external leaks and a head check done as well. this is a simple chemical test to check for exhaust gasses in the cooling system, start here.
Nov 11, 2017 at 3:14 AM
STEVE W.
CERTIFIED EXPERT
Yep, coolant does not just vanish without either a leak or burning it through the engine. The gurgling you are hearing is air in the system moving around. Most likely reason is a bad head gasket from running the coolant low and overheating the cylinder head.
Nov 11, 2017 at 6:29 AM
RSAND72
MEMBER
If i keep driving it will it damage more and is there any visible way of knowing the head gasket is gone? The oil is clean
Nov 11, 2017 at 8:37 AM
STEVE W.
CERTIFIED EXPERT
Using coolant with no visible leakage is a good clue of a bad head gasket. Run your hands around the floor to see if maybe it is a heater core leak, but on a 2014 I would doubt that. Do a cooling system pressure test and the combustion gas test to find out what the issue is.
As for driving it. Yes, it will do more damage and could easily destroy the engine if it is burning coolant, it will also damage the converter.
Nov 11, 2017 at 10:22 AM
RSAND72
MEMBER
The radiator is still full no oil anywhere. just checked oil again it is clean not milky. who does the tests on the engine?
Nov 11, 2017 at 1:57 PM
STEVE W.
CERTIFIED EXPERT
You can do them yourself, many of the chain parts stores have loan a tool programs and you get the tool and do the test. They basically sell you the tool and when you return it you get your money back. For the combustion test you also pay for the fluid that you use in the test.
It is full now but where did the coolant go before? That is the question.
Nov 11, 2017 at 3:25 PM
RSAND72
MEMBER
I am booking it into Holden this week. Thank you for all your advice.
