gurgling noise when engine is idling
2004 HONDA ELEMENT
230,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
CMGARCIA
car has faint gurgling noise when idle. It goes away when put in park. does not continue when the car gets turned off.
Apr 26, 2022 at 12:07 PM
This could be a couple of things. First, make sure the engine coolant is full. If low, there could be air on the heater core under the dash.
Next, pay attention to if it seems to only happen when the AC is used or the Defroster.
I'm assuming you hear it in the vehicle. If it is loud enough to record, do so and upload it for me to hear.
https://www.2carpros.com/articles/engine-coolant-59420607
I will watch for your reply.
Apr 26, 2022 at 7:54 PM
CMGARCIA
Hello, my radiator reserve was bone dry. I filled it and noise has gone away. Thank you very much!
May 2, 2022 at 12:27 PM
You are very welcome. Since it was empty, check it again after driving it to make sure the coolant wasn't all drawn into the engine. It may still be low and require more.
Additionally, check to make sure nothing is leaking. Here is a link you may find helpful:
https://www.2carpros.com/articles/car-is-leaking-coolant
Let me know and thank you for the update. If you have other questions or if I can help in any way, let me know.
Take care of yourself,
May 2, 2022 at 8:24 PM
